Spring Compressor Alternatives
Old Oct 28, 2004
civictuner's Avatar
civictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trusted
anything else to use than a spring compressor to install my Tein S-Techs?? i cant locate a spring compressor to rent so i wondering what u ppl did... NO I DONT WANNA TAKE IT TO A PRO!!
Old Oct 28, 2004
shmik1's Avatar
I had 2 friends helping with mine, and we managed stepping on it while taking it off and 2 ppl push down as 1 does the bolt when ur putting em on, then of course finish tightening once they're on ur car..
Old Oct 28, 2004
TeLLy's Avatar
Yes, it's an Acura EL
You know, even though I've had a compressor on hand for all my spring installs, a few times we didn't even bother using it. The nuts came right off, the springs didn't pop or anything. And putting new springs on was dead easy, again, without a spring compressor.
Old Oct 29, 2004
2k2civic's Avatar
Sorry, can't help you....I had a full shop while doing my suspension and thus had a spring compressor.
Old Oct 29, 2004
v8eaterokv6's Avatar
i have a new home do u
ok this is what i do get two tie down straps the wratciting ones. loop one around the spring on each side and tighten them up. works good
Sep 26, 2023 06:44 PM
mrohitredd
40
Sep 9, 2017 12:03 PM
mjdiaz89
Jun 21, 2016 09:26 PM
jzhartman
22
Jul 23, 2015 10:42 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
