Air Conditioning Post issues about air conditioning here
2010 A/C compressor will not engage
Old Jul 8, 2020
rogersracing89's Avatar
rogersracing89 is an unknown quantity at this point
Just bought car from guy who said dealership recommended replacing expansion valve. Ac quit the other day. Checked pressure low side showing retard. Of course checked fuses and relays. Compressor spun freely. So I changed expansion valve. Pretty much same issue compressor will not engage.
Old Jul 8, 2020
Wankenstein's Avatar
Re: 2010 A/C compressor will not engage
Just a suggestion for the future: If someone is selling a car and says it just needs "this part" to work, and especially concerning the a/c system which the typical sales pitch is "it just needs freon", Tell them to either fix it first, lower the price considerably, or walk away from it.
Is the compressor engaging? if not, did you tap on the compressor pulley while the engine is running, climate control + a/c engaged to see if it's an air-gap issue between the compressor clutch and solenoid? Leaking compressor or other areas? This may help: https://blog.firestonecompleteautoca...oubleshooting/
Old Jul 8, 2020
Yes I tried that. Read a few threads and that’s the common fix. But not in this situation. No leaks pressures at static are good. Wondering if it could be the thermal protector set
Old Jul 8, 2020
Here is a similar thread: https://www.civicforums.com/forums/3...nt-engage.html
Hani4g
Jul 31, 2016 06:02 AM
BJB
Sep 14, 2015 11:16 PM
alexkharden
Apr 23, 2015 07:13 PM
Mackln308
Mar 26, 2011 06:01 AM
RS4DUKE
Oct 20, 2004 03:06 PM
