2004 Civic engine cutting out
Old Mar 4, 2025
OzhondaAU's Avatar
OzhondaAU is an unknown quantity at this point
My 2004 Honda Civic GLi (190,000km), the engine cuts out whilst driving, both when engine under load and idleing. I've replaced the fuel pump and filter, to no avail.
Engine starts and runs fine, no other symptoms.
Appreciate your insights to diagnose what's causing the engine to cutout. Ignition renewed a year ago, including new cam sensor, crank angle sensor and timing belt.
I am selling the car, so will be honest to new owner, just want to ensure a smooth transaction and not be beaten down on price.
Old Mar 4, 2025
Colin42's Avatar
Re: 2004 Civic engine cutting out
Does it act like you turned the key off or like it runs out of gas? Everything else is still on when the engine dies?
Old Mar 4, 2025
OzhondaAU's Avatar
Car starts fines, drives fine, but engine dies without notice, no stumble or hesitation, just shuts off.
Engine does not want to restart. Give it 5 minutes and engine finally startsup. Got me baffled.
Old Mar 6, 2025
Colin42's Avatar
Might be losing spark, no engine codes?
Old Mar 6, 2025
OzhondaAU's Avatar
Not sure on losing spark.
A year ago i had the camshaft position sensor and cam angle sensor replaced when it lost spark. No codes showing.
Old Mar 6, 2025
Colin42's Avatar
Oe sensors?
Old Mar 8, 2025
OzhondaAU's Avatar
Yes, believe you'd be correct.
Engine won't start, same issue as two years ago when needed camshaft sensor and crank angle sensor.
Mechanic repairs will cost more than what the car is worth.
Decided to scrap the car, not economically viable to repair.
Cessna99
Dec 27, 2018 12:55 PM
krs
Oct 21, 2013 10:04 AM
Thaik
Jan 19, 2013 06:11 PM
