Catalytic Converter
Old Sep 30, 2025
Mark3555's Avatar
Mark3555 is an unknown quantity at this point
Catalytic Converter
I purchased a 2002 Honda Civic DX, that had an automatic to manual transmission conversion. The catalytic converter is built into the exhaust. Seem to only have wiring for the downstream O2 sensor (scanner only reads this one). They gutted the cat so it no longer functions. I have been to the junk yard for other parts, some of the 7th gen Civic seem to be running a exhaust with the catalytic mounted externally. I assume I need a catalytic converter, trying to determine the correct one for this vehicle it does have a 1.7 l JDM motor in it.
Old Oct 1, 2025
Colin42's Avatar
Re: Catalytic Converter
The upstream o2 should be right at the top of the cat. The car would be throwing codes without one. The downstream sensor will be on the pipe after the cat.
if you buy a new cat you might only get a year out of it before it starts throwing codes again
Old Oct 1, 2025
Mark3555's Avatar
The wire harness only has a connector for the downstream sensor. So I assume that if I get a cat built into the exhaust I can plug it like it is now. Trying to purchase the correct cat.
Old Oct 1, 2025
Colin42's Avatar
So it sounds like when the jdm engine was installed they used the jdm harness. The jdm harness only has the upstream sensor connector. On the jdm and ex cars the downstream sensor connector is on the body harness. Your car is not going to have this. Do you know what computer is in the car?
Old Oct 1, 2025
Mark3555's Avatar
It has a 2003 civic EX in it. I had to replace it had injector issues.
Old Oct 1, 2025
Colin42's Avatar
You're going to have to add the connector and wires to the ecu if you want to have the dowstream sensor.
What codes do you have?
What exactly are you try to do?
Old Oct 1, 2025
Mark3555's Avatar
P0141
Pepe10
Apr 29, 2024 07:17 AM
RizeLe
Jul 15, 2012 02:15 PM
86civic1300
Oct 19, 2010 08:56 PM
Jonauto
Oct 21, 2003 12:18 AM
