Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
can i change the location of my catalytic converter
Old Mar 29, 2012
RizeLe's Avatar
RizeLe is an unknown quantity at this point
ok so i have a 98 civic cx and i hate that the catalytic converter is attatched to the headers. So is there anyway i change the location of the catalytic converter? but i dont want to spend alot of money to buy new headers and converter and exhaust system. is there another model of civic i can just pull it off and swap it out with mines?
Old Jul 15, 2012
tohokujin's Avatar
tohokujin is an unknown quantity at this point
Re: can i change the location of my catalytic converter
You can but there may be some problems associated with doing this:
1. Moving or modifying an emissions device MAY be illegal. State and Federal laws apply.
2. If you do move it, say farther down the exhaust tubing, you may run into a heat problem- converters get very hot.
3. There is at least one sensor (oxygen?) attached to the converter and depending on where the converter is moved to, the sensor(s) will have to be rewired.
vtecbrah
19
Jun 5, 2015 09:38 PM
Shakzhussain
May 17, 2015 12:03 PM
BootyDo
May 8, 2015 05:36 PM
jessicakaybby
Apr 20, 2015 12:11 PM
ayzan
24
Apr 17, 2002 06:55 PM
