P1259
Old Jun 19, 2024
chubs's Avatar
chubs is an unknown quantity at this point
P1259
Hey I’m new here. I have a 2002 ex my. I have a p1259 code that I can’t figure out. I have put two new vtec solenoids in. I cleaned and replaced all the bad grounds and ohmed it out. I’m getting power to the plug and everything looks good but every time I go over 4000rpms the light comes on and puts me in limp mode. Any suggestions on what else I should be checking and has anyone else had a similar issue?
Old Jun 20, 2024
Re: P1259
oil levels
Old Jun 20, 2024
chubs's Avatar
Re: P1259
Oil is about a half quart over I will change it again this weekend and see what happens.
Old Jun 21, 2024
Colin42's Avatar
Re: P1259
Aftermarket vtec valves? Wiring looks ok?
Old Jun 21, 2024
chubs's Avatar
Re: P1259
Yes both are aftermarket. I looked at reviews before I bought them. The wiring does look good. Im leaning towards maybe an ecu issue because about a week ago at the Dunkin drive thru my gauges dropped and my lights on the dash came on then when I started driving off everything went back to normal.
Old Jun 21, 2024
Re: P1259
check if alternator bolts are loose
Old Jun 24, 2024
BrotatoChip's Avatar
Super Moderator
Re: P1259
There are a few pages of troubleshooting steps for that fault code in the service manual.
Carnage65
Jul 23, 2022 11:25 AM
Turtlekingmaste
21
Jan 3, 2021 07:44 PM
Djmixmode
Dec 5, 2020 10:01 AM
skaterboy2214
Mar 11, 2014 05:37 PM
Daguls
May 16, 2011 04:02 PM
