Coolant Overflow Tank Cap - Airtight or ?
Old Feb 10, 2025
hondaleut's Avatar
hondaleut is an unknown quantity at this point
Hello,
I have a 2004 Honda Civic LX with the 1.7 engine and I'd like to know if the cap to the coolant overflow tank is supposed to be seal up air tight when tightened down?\
I was checking the one out on my Honda today and when I turned it upside down (cap towards the grounds) coolant leak out around the cap threads.
Is that the way they work or do I need to get an o-ring for the cap or perhaps replace the overflow tank altogether?
Thanks,
Hondaleut
Old Feb 10, 2025
betdriver01's Avatar
betdriver01 is an unknown quantity at this point
Re: Coolant Overflow Tank Cap - Airtight or ?
try with this like i did. i applied teflon sealant tape to the threads. i dont know how long will hold leaking for you. but in my case its still working.,
Old Feb 10, 2025
definitely not air tight. If something happened where the overflow got overpressurized and it was an airtight cap, that overflow tank would probably explode
Old Feb 10, 2025
huh, is tank full? If so, you have a blown headgasket and it is gonna start overheating in no time...
Moved thread to engine section
Old Feb 14, 2025
Harry Hemi's Avatar
Harry Hemi is an unknown quantity at this point
If you have coolant leaking out of y9our overflow tank, your headgasket is blown. Thats the telltale sign of a blown HG for this particular engine. Ask me how long it took me to find out before I found this forum.
Old Feb 17, 2025
lollygagger8's Avatar
lollygagger8 is an unknown quantity at this point
Def sounds like a head gasket issue as coolant over flowing out of reservoir is a tell tale sign
skrrttt
Aug 22, 2024 06:27 AM
Filthy615
Jan 6, 2020 08:03 PM
Sionolann3
36
Jan 22, 2017 06:40 PM
Turbo351
Oct 22, 2008 06:36 PM
SOHCVTEC
Apr 26, 2002 07:10 PM
