Vented cap for coolant tank 01 coupe SI?
Rep Power: 0 Vented cap for coolant tank 01 coupe SI?
I bought my car used and I think it has the wrong cap on the coolant tank.
Can someone post a pic of the cap on theirs please? Does the cap have a built in vent of some kind? Thanks in advance.
Rep Power: 787 Re: Vented cap for coolant tank 01 coupe SI?
are you from canada? most 01-05 civics have a double cap on the radiator. theres the main metal one, and then a black plastic cap that goes over it which is not needed. i actually took mine off cause the metal looks nicer.
Rep Power: 0 Re: Vented cap for coolant tank 01 coupe SI?
Thanks for replying. I'm not referring to the rad cap. I meant the cap on the coolant resevoir (overflow tank) or whatever you want to call it. Thanks,
oh that one should just be a white plastic cap with a notch to turn it with. i can snap a pic if you want. its not vented but its not pressurized either.
(not my pic). its the white cap next to the + battery terminal area
blazebrown
18
06-02-2019 12:31 PM
lilrob1213
37
06-29-2015 06:45 PM
Jro773
06-09-2015 06:38 PM
Blaster30
04-22-2015 12:21 PM
Lightman
11-10-2001 06:44 PM
