want more mpg, new to this.
Old May 15, 2023
ncc74656's Avatar
ncc74656 is an unknown quantity at this point
just got an 01 civic. has some issues but id like to boost its mpg as much as possible. anyone have recommendations for this? do small turbos help with new fuel mapping on these things?
im not well versed in the world of spark plugs. this is my first car.
thanks.
its got the vtec engine with 240K miles
Old May 15, 2023
Re: want more mpg, new to this.
the ECU in these cars are not programmable, you will need hondata
Old May 16, 2023
Colin42's Avatar
Check out some hyper miler forums they'll have some things you can do
Old May 16, 2023
FRSam's Avatar
Click Here
It’d take years to recoup any major investment in fuel economy for these cars. I suspect more time than the car has left.
Old May 17, 2023
ncc74656's Avatar
guy i bought it from said he just put a reman trans in it. i was considering buying a rebuild kit for the engine as they are cheap.
Old May 17, 2023
FRSam's Avatar
Click Here
Cheap if you know what you're doing, and even then, there's more that goes into a rebuild than just a rebuild kit.
Just use the car for what it is; cheap and economical transportation. Like Colin said, there are some hypermiler forums that probably focus on this generation of civic, but any substantial investment would yield little benefit because:
1. These cars are already very fuel efficient
2. The only real fix for most cars is weight, but these are already about as light as you can reasonably get without compromising safety.
...but I digress. It's your car. Do as you please. I personally wouldn't waste my time. Alternatively, you could just buy a Civic Hybrid.
Old May 18, 2023
ncc74656's Avatar
yea, i paid 800 for this guy. its got a bit of a valve knock, gonna check lash when i do the head gasket. i was considering pulling the engine and doing a full rebuild on it. probably do it for like 350-400 or so? just finding the motivation. im pretty sure its been overheated really bad a few times
Old May 19, 2023
Colin42's Avatar
Just buy another motor
Old May 19, 2023
ncc74656's Avatar
you never know what your getting with a used motor tho, could have the same problems? or worse
Old May 19, 2023
and what is the MPG right now?
Old May 19, 2023
FRSam's Avatar
Click Here
Okay, this dramatically changes things.
Improving fuel economy should be the least of your concerns. Focus on having a functional car first.
Old May 19, 2023
Colin42's Avatar
That's why you huy one with a warranty, like a jdm engine
100% this
corysam
General 8th & 9th Gen
Mar 26, 2020 07:58 AM
mililani
Feb 21, 2017 07:00 PM
rrodgers
Mar 9, 2010 06:22 PM
mikem317
Jun 16, 2007 11:48 AM
bassbuddy999
Apr 20, 2007 10:11 AM
