Question on vapor bulb on end of fuel rail [solved]
Old Sep 5, 2023
Motomike's Avatar
Motomike is an unknown quantity at this point
I have a 2004 Honda Civic EX coupe 1.7. At the end of the fuel rail there is a little plastic tank with an opening with a green cap. I think it has to do with a vapor line. When I swapped engines I noticed the tank on the newer engine did not have the green plastic cap, it was open. So I put a vacuum cap on it so it would not leak. Could someone please explain to me what this little tank is for and should the tank have a schrader valve at the opening for testing purposes. I can't recall if the other tank had a schrader valve. Thanks
Old Sep 6, 2023
BrotatoChip's Avatar
Super Moderator
re: Question on vapor bulb on end of fuel rail [solved]
This thing? It is a service port for the EVAP system. No idea if it has a valve but I would guess not. Would cause a vacuum leak if left open.
Old Sep 6, 2023
Motomike's Avatar
Okay, Thank you, I appreciate the information. That's all I need to know.
Mike
sinceasar
Aug 18, 2019 08:11 AM
rbeatty
Feb 1, 2013 06:11 PM
brownie_602
Mar 26, 2012 08:37 PM
Mex
Sep 3, 2002 03:11 PM
huyqvu
Feb 8, 2002 09:22 AM
