Fuel Injector/Fuel Rail Question
Old Jan 7, 2011
sinceasar's Avatar
sinceasar is an unknown quantity at this point
Just installed new o-rings on my injectors, they were tight going into the fuel rail, so tight, that they ripped (2 out of 4). What can I do to lubricate them to get them into the rail without ripping.
Second. My honda CRX manual shows fuel rail nuts torqued to 108#. I sheared my bolts at just over 20, is that a misprint?
Thanks
Old Jan 8, 2011
b0ssman's Avatar
b0ssman is on a distinguished road
Re: Fuel Injector/Fuel Rail Question
Thanks
oem fuel rail or aftermarket?
I'm assuming this is a misprint and your manual is probably not a Helms.Get rid of the chilton's and buy a Helms,you'll never have wrong info again.The fuel rail bolts need to be decently snug but not extremely tight.
I suggest a light oil on the O-rings and place them in the injector ports of the manifold first,make sure they are facing the right way and then gently place the fuel rail over them.Once you do tat use even pressure of the fuel rail nuts to slowly slide everything into place(do a few turns on one of the nuts then go to the otherside for a few turns,back and forth like that.Go slow and give the O-rings time to compress to fit the hole you are shoving them in.
Old Jan 9, 2011
wetpinkpants's Avatar
wetpinkpants is on a distinguished road
I put a little 5w20 oil on the out side the o ring
Old Jan 9, 2011
lazlong's Avatar
Quit feeding the troll. I already answered this yesterday 11 minutes after it was posted in the other forum.
Old Aug 18, 2019
bbynams's Avatar
bbynams has a spectacular aura aboutbbynams has a spectacular aura aboutbbynams has a spectacular aura about
The fuel injectors are a very tight fit. Getting the old ones out is like pulling teeth! If you know how to get the air cleaner off, I'd say you could really do this job without any instructions. The retaining clips are a PITA because there's no way they can go back on first. You can't create enough pressure on the fuel rail to seat the injectors with or without snapping the ends off as you're doing it. I remember being surprised you can find a set for < $50.00!
There aren't a lot of extra parts needed; most people could probably reuse the retaining clips if you don't drop them into the engine. A multimeter set to 200 ohms might help you diagnose a bad (new) one before it gets started, but I can't see any point in just replacing one fuel injector if that's the cause of the problem. It looked like most places sold 4 at a time. And trying to put 100 ft lbs on a 10 mm bolt is asking for it, btw...
sinceasar
Jan 7, 2011 08:37 PM
TransformedBG
Bolt-on Engine Performance
Mar 25, 2006 12:58 AM
Civic02playa
Engine Swaps
Oct 28, 2004 07:52 PM
mongo
Sep 26, 2002 04:00 PM
Zillaaa
Aug 27, 2002 08:56 PM
