Fuel Injector/Fuel Rail Questions
1990 CRX SI. Just installed new o-rings on my injectors, they were tight going into the fuel rail, so tight, that they ripped (2 out of 4). What can I do to lubricate them to get them into the rail without ripping.
Second. My honda CRX repair manual shows fuel rail nuts torqued to 108#. I sheared my bolts at just over 20#, is that a misprint?
Thanks
Thanks
Re: Fuel Injector/Fuel Rail Questions
I always use WD-40 when putting in new gaskets. Are you sure it doesn't say "inch-pounds" not "foot-pounds"? 108 in-lbs= 9 ft-lbs. 9 ft-lbs sounds about right.
ZeroDegreze
Jun 17, 2015 11:10 PM
werdnahall
May 17, 2015 11:37 AM
superstanko
Apr 28, 2015 04:38 AM
