Air leak sound, few seconds after engine is turned off [solved]
Getting a strange air escape sound coming from around the pcv valve area.
Had just replaced pcv valve and hose. The hose was cracked and I thought that was it but the air escape is still ongoing.
Other issues I'm dealing with are the fans not activating. Replaced coolant switch and temp sensors with Duralast AutoZone brand and still no luck. I'm going to return it and buy a different brand. Following comments that had similar issues with it not working.
Radiator cooling fans work with AC on or by doing a bridge on the sensor connector.
Fuses are good.
Vehicle is 2005 civic lx 290k miles.
Already went through the head gasket once about 100k ago. Hoping it will last a little longer.
Fuses are good.
re: Air leak sound, few seconds after engine is turned off [solved]
Always get the oe parts when it comes to honda and electronics.
air leak noise might be normal, maybe the evap system.
No ambient sensor that I'm aware of.
Denso should be the correct brand.
randun13
May 27, 2012 12:36 AM
civiczzz
May 21, 2012 08:19 AM
johnny626
Sep 30, 2010 08:44 PM
