VTEC wiring help [solved]
Old May 31, 2023
hdfxrs91's Avatar
hdfxrs91 is an unknown quantity at this point
I have seen multiple threads on wiring a non-VTEC engine to adding a VTEC. however, I’m looking for something else, specifically wire colors.
A little background. 2003 EX Coupe, D17A2. I pulled my engine/manual trans to rebuild the trans and replace water pump, timing belt, etc. After all said and done, my oil light was on and a P1259 code lit up. I let it go after confirming I had good oil pressure. Fast forward to the day I decided to look at things. I found that the connector for the oil pressure sensor is the same as the spool for the VTEC. Problem is that the connector was broken so I had spliced my own. I stripped back the black cover and and found that I had the yellow/red wire connected to the spool and the green/yellow connected to the sensor. Dumb of me. I put the yellow/red to the sensor and the oil light finally went off. Yay! I spliced the remaining green/yellow to the spool, but I still get the P1259 code.
All I’m asking here is, is that green/yellow wire supposed to go the the spool or did I miss something. For the life me I have searched and searched but cannot find anything to answer that question.
Can someone help, please? Thank in advance.
Old Jun 1, 2023
hdfxrs91's Avatar
re: VTEC wiring help [solved]
In case anyone is wondering, after an exhaustive search of a working link for the service manual, I was able to confirm that the green/yellow wire is indeed the VTEC solenoid connection. The yellow/red is straight shot from the engine oil pressure switch to the light in the dashboard.
Old Jun 15, 2023
hdfxrs91's Avatar
Re: VTEC wiring help [solved]
Just want to add... I went to the junkyard an found all the connectors and wires I needed. Even found a VTEC solenoid assembly (keeping as a spare). Hooked it all up and now no oil pressure light but I still had the P1259 code. I put my original VTEC solenoid assembly back on and now everything works like it should. Lesson learned. Get genuine Honda parts for stuff like this. The solenoid was something I picked up online, I think from eBay.
Old Jun 15, 2023
thanks for feedback and sorry for not being too much of help, but glad you got it working.
Emmaleigh
Exterior
May 3, 2022 07:59 AM
nuribe_90
Transmission swap
Jan 29, 2022 03:00 PM
jemdogs
Lighting
Mar 18, 2016 12:33 PM
SlimRisk
Aug 11, 2012 12:41 AM
