Car hesitates while cruising
Old May 18, 2024
pippo's Avatar
pippo is an unknown quantity at this point
Hi Fellow Members,
2001 civic EX, 179.000 miles. original owner. Upon gentle acceleration or just keeping up a steady cruising speed, say, 40 mph, car hesitates/stumbles slightly to the extent you can feel it. Thing is so far there is no check engine light illuminated to assist in determining the cause. I know that sometimes the computer will set a code but not illuminate the check engine light (right??). If so, please advise and I will check for codes (cant do it just today, but will asap if necessary).
Meanwhile, one question I have is : What symptoms can this car have and it NOT be connected to a sensor that would throw a code? Bad /clogged fuel pump? Bad coil pack? Bad wires supplying coil packs? Bad/dirty air filter?
Thanks, people.
Old May 19, 2024
Colin42's Avatar
Re: Car hesitates while cruising
Check for codes, might be a slightly clogged cat, maybe a lazy a/f sensor
Old May 19, 2024
pippo's Avatar
Thanks, Colin. What is an af sensor? Also, do you know if the fuel filter is connected to the computer such as to trip a code if it is clogged?
And if it may be bad coil pack towers do you know what the resistivity in ohms should be for them? Thanks.
Old May 19, 2024
Colin42's Avatar
A/f sensor is your primary o2 sensor. Car isn't smart enough to have codes for the filter. It's just the sock in the tank. No idea what the xoil pack resistance should be
Old May 21, 2024
pippo's Avatar
Colin (or other members), I pulled a code 45, (SRS light blinking 4 times fast, the 5 times slow, NOT the blinking of the check engine light). Also known as P0780 according to this site linked below. BUT other sites say cod 45 has to do with fuel system (O2 sensor/EGR/MAP sensor). How confusing Which is the right code diagnosis?
https://www.google.com/search?q=hond...t=gws-wiz-serp
Should I proceed to gamble to try to replace a solenoid? Never did that before. Are there more than 1 solenoid? The article also mentions that it could be other things other than the solenoid, I think.
Thanks.
Old May 21, 2024
Colin42's Avatar
Get an actual scanner, they're like $20
Old May 21, 2024
pippo's Avatar
So weird, AZ and Adv Auto both found nothing wrong with my system, no codes stored anywhere, using their $1,000,000 computer scanners. I guess thats good news. Anyway, thanks for your support, Colin.
Old May 21, 2024
Colin42's Avatar
The o2 sensor won't always throw a code. Quick check for a clogged cat would be to loosen the manifold bolts at the head a little and see if it runs better. Obviously it will be louder
Old May 22, 2024
pippo's Avatar
Right- also, easy to do, change plugs. O2 sensors are also cheap/easy. Thanks, Colin.
Old May 22, 2024
Colin42's Avatar
Make sure you buy the correct ngk plugs and denso o2 sensor. Rockauto has both
Old May 22, 2024
pippo's Avatar
Is there only the downstream O2 sensor? Or are there 2 sensors? If 2, should I replace BOTH?
Old May 23, 2024
Colin42's Avatar
No the upstream one is the one you need. It's what measures the air fuel ratio
Old Jun 2, 2024
Kalebs car's Avatar
Kalebs car is an unknown quantity at this point
Pippo, did you ever figure out the issue? I am having the same problem with my 05 civic. https://www.civicforums.com/forums/3...ml#post4816587
EarleD
15
Feb 22, 2021 08:36 PM
Coldpizza
17
Feb 13, 2014 05:25 PM
vishmastaa
Oct 21, 2013 06:35 AM
giafam4
19
May 26, 2010 07:52 AM
hugothepoolman
Oct 2, 2007 09:14 AM
