Ignition timing issue
Old Sep 10, 2025
Neon_Nightrider's Avatar
Neon_Nightrider is an unknown quantity at this point
Lot of work done, and still some issues, any ideas?
All new sensors, water pump timing kit, verified timing, verified valve lash, new sparkplugs, fuel injectiors, ignition coils.
Old Sep 11, 2025
Colin42's Avatar
Re: Ignition timing issue
What's your issue?
Old Sep 11, 2025
I feel like the ignition timing should be more stable than what is in the picture.
I think the timing going +13 to -3 in seconds is not "normal"
It is not misfiring but the ignition timing should be much more stable than it is.
I did replace the water pump and timed everything correctly mechanically, will hope this is related to the other harness/ECU issues.
If anyone else has a scan tool with live data; I would appreciate seeing your ignition timing readings on live data to compare.
Old Sep 12, 2025
FRSam's Avatar
Click Here
If there isn't any active symptom, I'd leave it alone. Could just as easily be that your OBD2 reader isn't accurate.
That said, if your crank sensor and timing is good, then the only potential alternative would be something like carbon build-up in the head.
blucib15
Nov 6, 2012 06:21 PM
ace.i.R
Mar 25, 2010 08:03 PM
asadrana83
Aug 26, 2006 01:21 AM
mclean987
Dec 27, 2003 05:16 PM
MangoEX
Dec 26, 2002 10:08 AM
