P1342 [solved]
P1342 [solved]
Hey guys, ok first, 05 Civic 5 spd m/t, 1.7 SOCH Non-VTEC, just got the DTC P1342 concerning low voltage to the knock sensor. Anyone have a clue on this? Just recently finished an engine swap and has been driving perfectly since and still does, just threw this code yesterday.
re: P1342 [solved]
Reset the PCM.
Check for poor connections or loose terminals.
Check the short in the wire between the PCM and knock sensor connector.
Check for an open wire between the KS connector.
Check for faulty KS, PCM of KS harness.
re: P1342 [solved]
Sorry took so long to reply but, turned out to be faulty KS so after removal and reinstall along with much bad mouthing of Honda engineers for there placement it is once again a fault free engine.
mykel115
Feb 22, 2002 07:13 AM
DriftR
Feb 21, 2002 08:18 AM
