Hose clamp for Power Steering?
Old Nov 11, 2020
brokercar's Avatar
brokercar is an unknown quantity at this point
Hey all-
Honda Civic 2001 lx
the hose clamp from the power steering to the rack is a goner. It's the hose that ends up on the Drivers side.
I don't know the pressure its under, but the original clamp was hardcore. I'm wondering what are my options? O'riellys only seems to sell normal clamps?
Old Nov 11, 2020
bachands's Avatar
bachands is just really nicebachands is just really nicebachands is just really nicebachands is just really nice
Re: Hose clamp for Power Steering?
Try OEM at an online Honda dealer. Shipping may make it a bit expensive.
It is possible that NAPA sells the heavier duty hose clamps though. Have you tried NAPA?
Old Nov 11, 2020
brokercar's Avatar
I just check. it looks like its the return line. From the rack to the reservoir.
Do I need a heavy duty clamp for this? Or can I get away with a normal one from O'riellys?
Old Nov 11, 2020
BrotatoChip's Avatar
Super Moderator
That line is still pressurized but no where near what the high side is. You could try a regular hose clamp and see if it leaks.
Old Nov 11, 2020
Looks like it's a spring clamp. You should be able to get away with a worm gear type just fine.
Old Nov 11, 2020
brokercar's Avatar
It was this totally rusted one I took off.
Idk. quick google around. Not much info no the PSI. It's the return line to the reservoir.
Best numbers I read was could be 400psi but really "A fraction of that"
They're cheap enough online. I'd rather not have to rip the car apart again. winter is coming.
unless anyone knows somfin....
Old Nov 11, 2020
Oh damn, looks way different than the parts diagrams make it look. Nevertheless, logic tells me there should be a flare at the end of the tube/pipe it slips onto that helps keep the tube on, and the clamp making sure it stays
Old Nov 11, 2020
brokercar's Avatar
Update.
Just ordered the clamp. Was like $5
Thanks all!
Didnt want to risk pissing red in the middle of winter.
Old Nov 11, 2020
That would warrant a trip to the doc's office. OH, power steering fluid. Gotcha.
Old Nov 12, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Just went through this repair but ended up replacing the whole PS return hose assembly as it had rotted at this area of the clamp.
The OEM Honda PS fluid I use is a clear/amber not red.
Old Nov 12, 2020
brokercar's Avatar
Hmmm. thanks for that. Ill look at the hose closely.
Nope. I use the red cheap stuff. Red like my pee.
teezyyoxo
May 4, 2017 10:36 PM
Sailorman3
Nov 10, 2013 11:27 AM
edrulz2003
Engine Swaps
15
Jan 10, 2007 10:22 PM
booba5185
Bolt-on Engine Performance
Aug 29, 2005 05:02 PM
cobrapimp
Mar 5, 2003 02:08 AM
