Car stalling at idle and misfire
Old Jul 28, 2020
MathewMatiyasic's Avatar
MathewMatiyasic is an unknown quantity at this point
I replaced the ECU, Fuel injectors, coil packs, egr valve, valve cover gasket, cleaned the throttle body and the Idle air control valve. Can't seem to figure out the problem. If anyone here has any ideas let me know.
Old Jul 28, 2020
Colin42's Avatar
Re: Car stalling at idle and misfire
Any check engine light?
Old Jul 28, 2020
Yes. It is for the misfires. P0300 P0301 P0302 all stored.
Old Jul 29, 2020
Colin42's Avatar
Check the engine timing
Old Jul 29, 2020
Compression test
If that test shows obvious problems, then follow that with a leakdown test
rcook52459
20
Feb 18, 2015 09:23 PM
drake94eg
Jun 14, 2013 07:53 PM
mooncake2
Jan 18, 2006 07:43 PM
B390LU
May 27, 2005 12:19 PM
Ouse
Oct 20, 2003 06:50 PM
