Need advice 2003 LX ECU
Old Apr 4, 2021
damien11's Avatar
damien11 is an unknown quantity at this point
So i bought a 2003 honda civic 2door EX auto trans off of marketplace cheap, i towed it home and i was very sure it had a bad ECM, i ordered a used ECM off of Ebay with the same matching numbers and received the key imobilizer with it as well, that fixed the poor running condition, now i have an issue with it wanting to cut out bad around 40mph, or in park when the rpms reach around 2500, i am now sure that the engine was replaced with a non Vtec engine, could the ECM be thinking that the engine is a Vtec and causing a timing issue? and how can i fix this if this is the problem, thanks in advance for any help that you might offer.
Old Apr 4, 2021
Re: Need advice please
any codes being thrown?
Old Apr 4, 2021
damien11's Avatar
yes, upstream and downstram O/2s and vtec solenoid
Old Apr 4, 2021
Do you know if that ECU came from a 2004-2005 civic? If so, one of your problems may lie there.
Old Apr 4, 2021
damien11's Avatar
it had the same ECM number as the original one in the car, Ebay seller listed as a 2003 civic
Old Apr 4, 2021
Look the engine code
look if solenoid is there
https://www.civicforums.com/forums/1...ation-d17.html
Old Apr 5, 2021
damien11's Avatar
ya, there is no solenoid there, thats how i knew the engine had been replaced with a non vtec
Old Apr 5, 2021
damien11's Avatar
Re: Engine code and VTEC location D17
its the D17A1 engine code as well
Old Apr 5, 2021
either of those
1 - you will need a non-EX or non-Si ECU
2 - you can install an EX engine head
mind you, the 04/05 have a wideband o2 sensor, 01-03 uses a narrow band
Old Apr 5, 2021
damien11's Avatar
can you suggest an ECU part number?
Old Apr 5, 2021
https://www.bkhondaparts.com/v-2003-...rol-unit-cabin
Old Apr 6, 2021
damien11's Avatar
can anyone suggest an ECU part number that you would suggest for my 2003 Honda Civic EX 2door with Auto trans and now a non vtec engine
Old Apr 6, 2021
you can call a dealership and ask
or try car-part.com for listings of scrapyards nearby you
Old Apr 6, 2021
damien11's Avatar
i cant find much info on how to read the ECU part numbers to know which one may work, can you recommend a sight that could explain how to read the ECU numbers?
Old Apr 6, 2021
https://www.civicforums.com/forums/3...vtec-ecus.html
Old Apr 6, 2021
https://www.civicforums.com/forums/3...ease-help.html
https://www.civicforums.com/forums/3...ml#post4617208
JulianLewis75
Oct 6, 2020 06:34 PM
Jesse Smith
Engine Swaps
21
May 28, 2020 07:19 PM
Linkage
Transmission swap
Apr 5, 2019 10:44 AM
Jdmguy69
Nov 2, 2016 02:20 PM
bricem
Mar 5, 2009 09:43 PM
