2003 Civic EX 5speed oil leak
Old Dec 11, 2020
Joseph Santos's Avatar
Joseph Santos is an unknown quantity at this point
There has been an oil leak on my Civic for a while now. Finally decided to crawl under there and see if I can spot where it's coming from. I found the location of the leak however I don't know the identity of the bolt / plug that the oil is coming from. Can anyone identify this for me? It's on the bottom rear of the engine, straight above the oil pan where the oil drain plug is. If you could tell me sizing and torque spec for this bolt that would be awesome. I'll attach a picture.
Thanks in advance for any help!!!
Old Dec 11, 2020
BrotatoChip's Avatar
Super Moderator
Re: 2003 Civic EX 5speed oil leak
It's not leaking from that bolt. That looks like an oil pump O ring leak to me. Part 17 in the pic below, part number is 91308-P3R-T01. It's like a $2 part but isn't an easy fix. Timing belt has to come off, oil pan removed, oil pump removed.
Old Dec 11, 2020
Thanks a lot! Just talked to my mechanic and he said to clean up the area and add some dye to confirm where the leak is coming from. Replacing the o-ring would definitely be a PITA!!!!
Old Dec 13, 2020
redlion4's Avatar
redlion4 is a jewel in the roughredlion4 is a jewel in the roughredlion4 is a jewel in the roughredlion4 is a jewel in the rough
The same leak I fixed in our 05 LX 5 speed. I had watched it drip for several years until deciding to do the timing belt, crank, and cam shaft seals along with that oil pump o-ring (also recommended to do the water pump, if it has not been changed). The garage floor has been dry after I fixed up the oil pan gasket/bolts that leaked after this work.
gts
Jan 4, 2020 06:47 PM
04civicexx
Dec 21, 2018 07:32 AM
Nosepicker
17
Aug 25, 2010 11:02 AM
7thgenchris
Apr 25, 2009 09:50 PM
deathcab
Dec 7, 2005 06:30 PM
