D17a2 massive cooilant mixing with oil
Old Dec 9, 2020
Daze0420's Avatar
Daze0420 is an unknown quantity at this point
Mass coolant mixing with oil cant find many places on this d17a2 for so much coolant to get into the pan. Anyone know how many gaskets can pass coolant into the oil on this engine. Been Used to working on dohc engines.
Old Dec 10, 2020
BrotatoChip's Avatar
Super Moderator
Re: D17a2 massive cooilant mixing with oil
The head gasket. Usually when they go bad it's combustion gases get into the coolant though.
Any work done recently?
Old Dec 10, 2020
Daze0420's Avatar
d17a2 coolant in oil
Recently replaced head gasket and thermostat from blowing the engine due to a faulty thermostat. After replacing all gaskets everywhere im still getting massive amounts of coolant in the oil pan instantly.
my real question is. How many gaskets on this engine could enable the coolant to flow into an oil passage. Only thing I havent messed with now is the water pump so im about to lean into checking that to see if there is a way for coolant to get to an oil passage.
Old Dec 10, 2020
merged threads - they are about the same issue
Old Dec 10, 2020
Daze0420's Avatar
just did the head gasket due to already having the same problem before cause everyones saying its the head gasket but same problems are still occurring. Kinda starting to think warped or cracked block. Thank you man.
Old Dec 10, 2020
Super Moderator
Was the head decked by a machine shop to ensure it was clean and flat?
Slicer1989
Apr 21, 2018 08:46 AM
Poopies
General 7th Gen
Aug 17, 2015 11:24 PM
mrmet1986
Sep 3, 2011 01:30 AM
lovinthevtec
Engine Swaps
Jul 11, 2007 01:18 PM
ST8RACE
Mar 4, 2007 10:42 AM
