limp mode: how can i disable it
Re: limp mode: how can i disable it
Lightweight flywheel shouldn't cause that code. I ran an ACT Streetlite for years more than a decade without that code popping up. Crankshaft sensor is on the opposite side of the engine (timing belt side adjacent to the crank pulley, about the 1-2 o'clock position if you're looking directly at the pulley). You likely have to replace the sensor (use Honda OEM for best results -- we've seen too many instances where people use a generic brand and it just gives them hell)
after market Crank Position Sensors do not work!!!!!!!! anyone reading this take heed. i can't believe they sell them nationally, but putting in OEM honda part solved all
my problems!
my problems!
well, that is quite well known...
if you just to a quick search, you would know that Hondas are very finicky with sensors, so we always recommend to use OEM...
Ramrod
Jul 30, 2018 11:19 PM
felixb555
Apr 12, 2017 01:58 PM
