3500 rpm acts like hitting rev limiter
Old May 11, 2020
luke1986's Avatar
luke1986 is an unknown quantity at this point
I got a 2002 Honda civic ex with 1.7 vtec
At 3500 rpm it acts like hitting a rev limiter.
I can not figure out what it would be.
One person said camshaft postion sensor but others say no. Any help would be greatly appreciated.
Old May 11, 2020
FRSam's Avatar
Click Here
Re: 3500 rpm acts like hitting rev limiter
Is there a check-engine light on?
Sounds like you’re in limp mode, which usually results from a faulty cam position sensor. Easiest way is with an OBD2 reader, provided there is a check-engine light.
Old May 12, 2020
luke1986's Avatar
yes check engine light is on haven't gotten it read tho don't know anyone with reader
Old May 12, 2020
FRSam's Avatar
Click Here
AutoZone will do it for free.
It sounds like it’s a cam position sensor issue, but that may not necessarily mean it needs a new sensor. Now would be a good time to check when critical components were last replaced (i.e timing belt: limp mode will engage if it skips teeth)
Old May 12, 2020
luke1986's Avatar
is timing belt hard to change?
Old May 12, 2020
luke1986's Avatar
My buddy changed timing belt around 25000 to 30000 miles ago
is camshaft position sensor hard to change?
Old May 12, 2020
FRSam's Avatar
Click Here
Timing belt is a bit of a pain in the *** to replace. Not difficult, just super time-consuming. You’re about half-way to needing a new one, but it should be fine. I’m trusting that he changed it correctly when I say that.
Sensor is easy to change, so you should hope it’s just that.
Old May 12, 2020
luke1986's Avatar
I hope that u was told that by a couple of buddies that it was the sensor
Old May 12, 2020
FRSam's Avatar
Click Here
That’s my guess given the information you’ve told me. Assuming it still runs fine (up to 3500 obviously) then I see no reason for it to be anything else.
Is the engine hesitating or bogging at all? Crappy idle? Hard to start?
Old May 12, 2020
luke1986's Avatar
Runs fine till by 3500 rpm.
it takes a little more cranking but not that much more
no other problems i can see or heard or find
Old May 12, 2020
Colin42's Avatar
Make sure you only use an OEM Honda sensor, don't use a cheap one from the parts store
Old May 12, 2020
check oil levels - that's the easiest step.
VTEC controlled by oil pressure, if it is low it will throw a limp mode
very common issue, tons of threads here on that
Old May 12, 2020
luke1986's Avatar
I went to auto zone and had code read and it says crankshaft sensor
Old May 12, 2020
luke1986's Avatar
They said it said no feed i believe is how he told me
Old May 12, 2020
FRSam's Avatar
Click Here
Are you sure they said crankshaft and not camshaft? It will not run well at all if the crankshaft position sensor is bad.
Old May 12, 2020
luke1986's Avatar
Ya I asked twice. He said it said no feed coming from crank sensor
I drive it just seems like a rev limiter at 3500 rpm
Old Oct 28, 2023
Whipple_Los's Avatar
Whipple_Los is an unknown quantity at this point
What ended up being the issue with this?
Old Oct 29, 2023
Colin42's Avatar
What's wrong with your car? And what did you mess with?
Old Jan 8, 2024
wingracer's Avatar
wingracer is an unknown quantity at this point
I can't answer for him but came here looking to find the answer to the exact same problem on the exact same car. Turned out to just be low oil. Freaking oil change place left the drain plug loose. Checked the oil, didn't even show on the stick. Borrowed mom's car to get a few quarts, filled it up and she runs great again. That's also when I noticed the puddle on the ground and oil dripping from the drain plug.
return_2020
Aug 22, 2005 10:22 AM
slamtank
Aug 22, 2003 12:55 AM
Samari
Jun 2, 2003 08:53 PM
lubomski
Jul 22, 2002 12:47 PM
ModNewbieHELPME
Nov 30, 2001 06:13 PM
