EVAP problem
Old Jul 24, 2020
bachands's Avatar
bachands is just really nicebachands is just really nicebachands is just really nicebachands is just really nice
EVAP problem
I thought I had this problem fixed, but I guess not so here's a new thread....I'll try to be to the point.
CEL was on - P1457. Replaced EVAP canister and CVS valve. CEL went off for a while but came back on. Now the code is P0497. I understand this should not be related to the gas cap, but I replaced it anyway just to rule it out. No change.
CEL still on for P0497. Replaced purge valve. It's only been a few days but I feel it should've gone off by now. Both the original valves (vent and purge) tested good when I applied 12 volts to the pins. Neither one seemed to be leaking when closed and had full flow when open. I tested the new ones before installing them and they were good also.
I am now thinking that either voltage isn't getting to one of the valves (ECM or wiring problem) or there is a restriction in one of the lines leading up to the purge valve.
I am trying to understand how the bypass valve works and determine if it could be causing the code. Anyone know if the bypass valve could cause this code?
Am I right in thinking the next step is to find someone with a bi-directional scan tool to command the valves on and off to see if they are getting power?
Old Jul 24, 2020
Re: EVAP problem
Erase the code already.
Old Aug 12, 2020
bachands's Avatar
Re: EVAP problem
It's been a couple weeks now...code never went off, but I think I found the problem.
First off, I found that the CVS valve connector was not on. So that was an obvious problem. I must have forgotten to re-connect it last time I was under there. I've connected it and erased the P0497 code. So we'll see if it comes back this time.
I am a little confused by the P0497 since the CVS valve is a normally open valve. That would mean if it's disconnected it couldn't close and then the ECU would detect a large leak. So I would've expected a P1457 or similar again. But honestly, idc....if the code never comes back I'll be happy.
Old Sep 14, 2020
bachands's Avatar
Re: EVAP problem
1 month later, code has not come back
bachands
General
Aug 13, 2020 12:55 PM
timbolio
Nov 4, 2018 03:39 PM
JD101
Oct 13, 2017 08:44 AM
KevinMCody
Jul 1, 2017 12:59 PM
mnwolftrack
Aug 7, 2012 09:37 PM
