Pitting in head
Old Jul 14, 2021
Jshorter's Avatar
Jshorter is an unknown quantity at this point
Pitting in head
I’m new to this forum so I hope I’m posting in the right spot. I have and 05 civic value package with 325k on the clock. I know very little aside from what I’ve researched the last couple days so bear with me. It’s been overheating for a long time but recently has gotten worse. I ripped it apart to check the head and the gasket. I can’t see a crack in the gasket, head, or block, so does this mean the head has warped from overheating therefore breaking the seal between the head and block? There is also a small pit on what I think is the problem cylinder. Could this pit cause a leak? Also some things to note: the cylinder where the pit is is much cleaner than the rest, also I noticed water in the oil when I took the valve cover off. When I take the radiator cap off there are bubbles when the car is running. Any thoughts? Warped? Or maybe the pit? Or maybe just wore out?
Old Jul 14, 2021
Re: Pitting in head
breached gasket.
too long heating the aluminum head = pitting.
headgasket and overheating info:
https://www.civicforums.com/forums/3...reference.html
Old Jul 15, 2021
BrotatoChip's Avatar
Super Moderator
Re: Pitting in head
I have fixed a handful of these cars with head gasket issues, not once could I tell where the leak was on the gasket.
alterman156
Mar 8, 2019 04:41 PM
Roadglide04
Jan 16, 2019 05:46 AM
billz28
Aug 14, 2016 01:02 PM
redright9
Jan 5, 2011 02:23 PM
HondaHowTo1
Jul 1, 2010 12:52 PM
