Multiple head gasket failure
Old Jan 4, 2011
redright9's Avatar
redright9 is an unknown quantity at this point
I have a friend selling a 1995 Civic with a blown head gasket... The problem is this is the third one in 20k miles... The shop said it maybe a sleeve in the engine slipped and may not be repairable.. Any thoughts?
Old Jan 4, 2011
Re: Multiple head gasket failure
did you have the head milled flat on the gasket side by a machine shop? usually if there was something to cause a headgasket to blow, it involves overheating and the head may have warped. then you will always blow gaskets until the problem is fixed.
Old Jan 4, 2011
redright9's Avatar
yes, the head was machined..
Old Jan 5, 2011
redright9's Avatar
I spoke with my friend again about this car ( I am wanting to buy it from him) and he said the shop told him (they havent torn it down or looked at it any further..he has just let is sit in his driveway now) that the cylinder sleeve may have slipped or something causing this to happen and it may not be repairable... does that sound likely?
Old Jan 5, 2011
i guess possible, but rare. could also be a cracked block. i think whatever the reason, the engine was abused or not taken care of. so if you buy the car, best bet would be swap in a different motor and not deal with these problems.
Old Jan 5, 2011
MindBomber's Avatar
Live for the Twisties
+1 Engine swaps in Hondas are very affordable for pre-2000 cars, if this is a becoming a routine problem then I'd suspect there is something wrong with the block and it wouldn't be worth repairing.
Old Jan 5, 2011
Stock 99's Avatar
^^ sometimes it's a more cost effective way to go.
Was the HG professionally done?
Could be it was just an amateur job. Although you'd figure 3x you'd get pretty good at it. LOL
Doing a headgasket isn't rocket science but you still have to be meticulous when you do it.
Could just be the head bolts have been in and out so many times they just won't hold tension properly anymore.
Old Jan 5, 2011
redright9's Avatar
So do these engines have sleeved cylinders?? The shop that has done the repair is supposed to be a reputable shop....Right now, it runs, low on power, like a slight missfire, bubbles in radiator and getting hc readings with an emissions test device from radiator/coolant. I guess I feel they must be missing something, maybe like what was said, maybe the bolts are stretched...
Old Jan 5, 2011
BlueEM2's Avatar
Whachya lookin at?
Youd think the second and third time the shop was doing it they would inquire into why the gaskets were blowing and know what the actualy problem is? A reputable shop will do that if someone brings the car back to them for a second or third time with a repeat problem. Sounds to me like they are just changing the head gasket, collecting their money and guessing as to what the actual issue may be. Take it to a different shop and get a second opinion. Better yet, tear it down yourselves and see whats going on in there.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
jherna85
General 7th Gen
Jul 9, 2015 08:10 AM
zaboomafoozarg
May 30, 2015 09:21 AM
HondaHomer
May 14, 2015 12:24 PM
