Car running hot after shifting funny
Old Oct 30, 2020
ddrriizz's Avatar
New Member
ddrriizz is an unknown quantity at this point
Hey guys, new to the civic world. Recently bought a 2004 Honda Civic with 200k miles. It’s my car I drive back and forth to work. For the first 8 or so months everything was perfect. Recently the car has been shifting hard into third gear, almost feels like it’s down shifting. Once it shifts hard my car instantly starts to overheat. If it shifts normal my car never overheats. It seems to happen more in the morning than in the afternoons. I’ve had the thermostat replaced, new radiator, new hoses, new cap. After all this replaced it still happens. I’m lost at this point. Please help if you have any input. Thanks!
Old Oct 30, 2020
BrotatoChip's Avatar
Super Moderator
Re: Car running hot after shifting funny
Head gasket failure is extremely common in these Civics, read up in the thread below. Is the check engine light on? What codes?
https://www.civicforums.com/forums/3...reference.html
Old Oct 30, 2020
ddrriizz's Avatar
New Member
No CEL no codes. My mechanic left it under pressure for almost 48 hrs and it never dropped. He thinks the head gasket is fine.
Old Nov 2, 2020
Super Moderator
They can pressure test the coolant system all they want, doesn't prove the head gasket isn't bad. Did you actually read the thread I linked? These cars don't fail normal head gasket tests. The first post in that thread has two different tests you can run to prove if yours is bad.
Kris Brauss
Apr 21, 2021 09:41 AM
ttharper
May 11, 2015 07:27 PM
aj_ej6_ferio
Oct 14, 2014 07:06 PM
Xyrodon
Jul 21, 2009 11:50 AM
00turboSI
Feb 15, 2007 10:24 PM
