05 civic dies when i take my foot off the accelerator.
Old Jun 21, 2020
Phillip Lloyd's Avatar
Phillip Lloyd is an unknown quantity at this point
we changed the head gasket and head. Now its like it is in limp mode or something. As long g as I give it gas it will run. As soon as i release the accelerator it dies. Can someone please tell me what I've done? Thank you in advance.
also we got back into the motor and checked that we were not 180 out of time.
Old Jun 21, 2020
Re: 05 civic dies when i take my foot off the accelerator.
180 out is impossible,
But timing belt installed incorrectly by 1 or more teeth can make it run like poop.
Got fault codes? Vacuum leaks? Valve clearance adjustments done correctly?
Old Jun 21, 2020
FRSam's Avatar
Click Here
Only asking because I made this mistake...
Is the Cam Position Sensor in properly?
Did you replace any sensors? Did you use OEM sensors or cheap AutoZone sensors?
One thing I will add: It should run in limp mode, though very poorly (at least mine did) if the sensor isn't in. Timing would be where I look first.
Ganzo2016
May 25, 2017 03:06 PM
cmorrison6
Dec 3, 2007 09:27 AM
Gutro
Feb 5, 2007 10:39 AM
matrix311
Arizona
Apr 7, 2005 09:46 PM
