View Poll Results: Why does my car lose power after turning off and restarting
What's my problem
100.00%
Please help
0%
Voters: 1. You may not vote on this poll
Loss of power after restarting when car is driven several miles
Old Jul 3, 2021
Bbarton's Avatar
Bbarton is an unknown quantity at this point
I recently bought a 2002 civic with vtec 1.7 and after I drive it for a while and car gets warmed up when I restart it after stopping it loses power and won't go over 3000 rpms until I let it sit for 15 minutes or so, please help me figure out the problem
Old Jul 3, 2021
FRSam's Avatar
Click Here
Re: Loss of power after restarting when car is driven several miles
What codes are you getting? It's engaging limp mode, which is a failsafe in the event that there is a mechanical fault.
Old Jul 3, 2021
Bbarton's Avatar
I haven't hooked it up to anything yet, I thought it was cat but done away with it
Old Jul 3, 2021
Bbarton's Avatar
Also after cooling for 15 minutes or so it runs fine until turned off and restarted
Old Jul 3, 2021
FRSam's Avatar
Click Here
Does the temperature gauge spike? What is the coolant level in the overflow reservoir?
Old Jul 3, 2021
Bbarton's Avatar
All the fluids are fine and the temp hand never goes past half way
Old Jul 3, 2021
FRSam's Avatar
Click Here
First thing to check then would be the codes. Can't really do anything until then.
Old Jul 4, 2021
in case you can't read numbers, your car is a 7th generation, not 8th generation.
Also, moved to engine section.
do you really need that pool?
from your posts... I recommend you take the car to a shop. Internet help depends on you doing the work...
ANW89
Jun 19, 2013 10:39 AM
cherry-anna
Jul 10, 2012 01:23 PM
kenji4862
Mar 28, 2005 06:00 PM
Jodster
Nov 19, 2003 03:34 PM
Chrisman8995
Mar 25, 2003 11:32 AM
