4,000 rpm rev limit 2001 Honda Civic dx 5spd
Old Jun 3, 2020
Axesizzle's Avatar
Axesizzle is an unknown quantity at this point
Check engine light is for o2 sensor, it also threw a code for vtec oil pressure switch but I have a non vtec motor. Anyway I replaced the oil pressure switch with a new one and that code went away. Still none the less no matter what gear i am in it will not let me go past 4,000 rpm( yes I know it's in limp mode but I want to know how I can fix the problem). If anyone has any advice please let me know thanks !
Old Jun 3, 2020
BrotatoChip's Avatar
Super Moderator
Re: 4,000 rpm rev limit 2001 Honda Civic dx 5spd
Care to share the actual faults?
Old Jun 3, 2020
Axesizzle's Avatar
I had codes for both the o2 sensor and oil pressure switch, replaced the oil pressure switch and the code for the oil pressure switch went away I still have a code for the o2 sensor. I thought that by replacing the faulty oil pressure switch the would let go further than 4k rpm but I am still having the same problem checked the oil and it right where it needs to be.
Old Jun 3, 2020
I think he was more asking what the actual codes were. e.g.P0[xxx]
edit: I seem to have dropped a few words
Old Jun 4, 2020
Axesizzle's Avatar
P0141(o2 sensor) I believe and I believe the other code was P2646 (oil pressure sensor)
nightwish_989
17
Mar 28, 2020 07:45 AM
Kiddta
Sep 28, 2016 01:03 PM
Todd Crump
Nov 9, 2013 11:02 AM
shawn_ashley6
May 15, 2008 08:50 PM
Goku
Jan 21, 2004 04:45 AM
