Check engine light
Old Mar 3, 2021
Bobfrazier5526's Avatar
Bobfrazier5526 is an unknown quantity at this point
Check engine light
We have included your original post below:
Hello all. About a month and a half ago I installed a k and n intake system on my 2005 civic. Everything was running good and sounded great. Today I was driving and a check engine light went on. I opened the hood and my filter that sits on the end of the tube fell off. After securing it it still has the check engine light. Any ideas on what it could be. Did it just throw a engine light because of that ? But to me it seams silly that it would throw a engine light because the engine has no way of knowing the filter fell off. Any help is appreciated
Old Mar 3, 2021
Re: Check engine light
get the codes
it's just speculation until you have them read.
Old Mar 4, 2021
BrotatoChip's Avatar
Super Moderator
Most parts stores (like Autozone) will read faults for free.
Old Mar 14, 2021
Engine code help
Recently my 2005 Honda Civic dx MT has thrown a check engine light. About a month prior I installed a short ram intake with no problems. The day it three the code I popped the hood and found that the filter had fallen off the tube. I just read the codes and I got P0113 and P0135. I looked it up and the first one is supposed to be a air intake temperature sensor and I’m wondering if my intake is causing that. The second one is o2 sensor code. How would I got about fixing these problems. I pretty new to working on my own car and I would appreciate any help. Thanks
Old Mar 14, 2021
merging to your previous thread. creating a new one will not help (will spread the answer, be asked the same thing in two different threads. etc..
a quick search on the forums will tell you that IAT, at the intake you replaced, so yes, it is intake related...
Old Mar 14, 2021
okay thank you I wasn’t sure if it was a good idea to bring backs old thread. Intake related as in the intake causes this and there is nothing wrong with the sensor. Also how would I got about fixing the other code. Should I just replace the A/F sensor?
Old Mar 14, 2021
the code related to the intake air temperature sensor, it could have been caused by you bumping into it during intake installation. That is what i meant it is intake related, so you should check it.
Old Mar 14, 2021
okay I’ll see if it’s connected properly. What would determine if I need to replace it? I really appreciate your help
Old Mar 14, 2021
search around the forums for a bit. 7th gen cars have been around for 20 years, plenty of info here.
Internet help means you will do the legwork
Old Mar 14, 2021
IAF sensor looks fine. I’ll probably clear it and if it comes back I’ll get a new one. Now about the p0135 code. It seams that I’m seeing it’s not actually a o2 sensor but a A/F sensor. Is it better to buy a oem A/F sensor or just go with a good aftermarket one.
Is the AF sensor located on the top of the exhaust manifold or under the cat?
Old Mar 14, 2021
Alright I think I know what’s wrong. I watched a video and I learned that if you remove the connector from the iaf sensor while the car is running it throws the po113 code(not sure what I was thinking at the time). I cleared the codes and only the po135 code came up. Should I go with the denzo 2349005 air fuel sensor or a oem Honda one. I’m having trouble finding links as I’m in Canada. Should I just get one from the dealer? Cause it seams that these cars are sensitive to aftermarket ones
Old Mar 14, 2021
FRSam's Avatar
Click Here
I'd go dealership. That's the only safe bet in my opinion. You may be spending more but it's mostly for the peace of mind.
Old Mar 14, 2021
it’s probably easier for me to get it there to
Old Mar 15, 2021
Colin42's Avatar
I got mine from Amazon, I'm in Canada.
Old Mar 15, 2021
do you happen to have a link I could use. Did you get a denzo one or a Honda one. I’ve seen the denzo one but the reviews said it was a fake one
Old Mar 15, 2021
Colin42's Avatar
Edited my post to include a screenshot, didn't show up in the post for some reason. Mine was genuine, just examine it before you install to make sure you didn't get a counterfeit part
Old Mar 15, 2021
that looks like the one I was looking at. I’ll compare the Price with the one from the dealer shop as I’ve heard these ones sometimes won’t work
Old Mar 15, 2021
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
I'd look into that Denso one on Amazon (#234-9005) if it were my car. The OEM Honda sensor would be around $330 CDN.
The part number for Honda is 36531-PLM-306 I believe for a 2005 LX.
Old Mar 15, 2021
I’m okay with shelling out the money for a oem part. I’m just worried that the denzo one won’t work
Old Mar 15, 2021
Colin42's Avatar
I had zero complaints, had it swapped in under 10 mins
leandro1.8
Dec 2, 2010 02:33 PM
Nelly
Jun 1, 2005 03:42 AM
navyedoc
15
Dec 25, 2003 10:34 PM
01WingsWestCivic
Mar 17, 2003 12:13 PM
