Misfires
Old Jul 15, 2020
gch23775's Avatar
gch23775 is an unknown quantity at this point
Misfires
I have a 2002 Honda Civic Ex Sedan with manual transmission with over 200k miles. It runs great. The only thing that I've noticed is a slight jerking when pressing the accelerator gently, so I always just make sure I'm either all the way off the pedal or accelerating hard. My CEL comes on from time to time and it gives me a P0300, P0301, P0302,P0303 and P0304. I just replaced the spark plugs thinking that could be the problem, but it still gives me the misfires. I want to check the fuel pressure, but I don't know where the test port is. I will do a compression test on it tomorrow, hopefully its not that. What should be my next step after testing the fuel pressure and cylinder compression?
Old Jul 15, 2020
GolNat's Avatar
Prelude Owner
Re: Misfires
What plugs did you put in? NGK Iridium? Did you check the gap?
Old Jul 15, 2020
gch23775's Avatar
Re: Misfires
I did use NGK. I did not check the gaps. I thought they came pregapped.
Old Jul 16, 2020
GolNat's Avatar
Prelude Owner
Re: Misfires
They do but I have had them be off before. The ones I put in my GTI not to long ago needed adjusting.
I'd check that before checking fuel and compression.
Old Jul 16, 2020
BrotatoChip's Avatar
Super Moderator
Re: Misfires
Does yours have EGR? The EGR runners are known to clog up and cause misfires in all cylinders.
Old Jul 16, 2020
Colin42's Avatar
Re: Misfires
this would be my guess too
Civicic
Oct 20, 2019 10:12 PM
Ian Grabowski
Jan 21, 2018 12:25 PM
matcab
Mar 26, 2015 01:40 PM
iPwn
17
Nov 17, 2014 09:40 AM
bighoss77
Jan 22, 2012 01:12 PM
