Oil in EGR intake port on the Head, problem?
Old Mar 15, 2021
Nephlite2k's Avatar
Shade Tree Mechanic
Nephlite2k is an unknown quantity at this point
Found this when taking off my water outlet. I'm not finding any oil in the intake ports, they are pretty dry. My car didn't have a EGR but the new engine I put in did. I took it off and replaced the water outlet with one without the EGR. Never had oil in this port on my old engine. Never had a EGR so not sure if it's supposed to have oil there. Though based on my limited understanding of them it doesn't seem like there should be. Just wondering if this is a problem or not.
Old Mar 15, 2021
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Oil in EGR intake port on the Head, problem?
Related to your breached head gasket or worn piston rings? Might want to check your PCV valve as well.
Old Mar 15, 2021
Nephlite2k's Avatar
Shade Tree Mechanic
Could give the PCV valve a look. If it were a piston wouldnt I be getting smoke or oil in other spots though? The exhaust and intake ports are both dry and clean. It's just that one port on the water outlet that has oil.
Old Mar 15, 2021
Nephlite2k's Avatar
Shade Tree Mechanic
So, I have discovered that port only goes to the EGR ducts on the intake manifold. So the only place oil can come from is the VTech solenoid. Solved my own problem it seems. Well, one of them anyway...
James Tyler
15
Mar 15, 2021 11:18 AM
rileyb22
Feb 28, 2012 04:43 PM
Towelrack
Jun 25, 2011 09:47 PM
utahbmxer
Oct 26, 2010 11:30 AM
02civic21
Apr 16, 2007 11:33 AM
