bad catalyc converter 2003 civic lx
Old Feb 27, 2021
Noe Torres's Avatar
Noe Torres is an unknown quantity at this point
Question bad catalyc converter 2003 civic lx
so my 2003 honda civic lx didnt pass the smog because the previous owner tried to modify it
does anyone know a way to fix this for cheap
any after market cats that will pass
o2 sensor as well
Old Feb 27, 2021
Re: bad catalyc converter 2003 civic lx
DIY Mechanical O2 simulator
Had a high flow cat on my 2002 ex that threw a P0420 code after some years of being installed . Mechanical O2 simulator did the trick to let me pass emissions. This trick also worked on my friend's 05 Honda Odyssey. As long as your state doesn't have a visual inspection, you're golden. If your cat is clogged, it's a bad idea, but it sounds like it's the opposite since previous owner tried to mod it (prolly hollow out the cat, if I had to guess). If you want an actual catalytic converter, however, I'm not 100% of any good aftermarket ones. I think magnaflow has a decent 49 or 50-state legal one? But I'm not sure how well it works or whether or not it'll throw a code after some time
That part number is still the same if you shop at autozone, but otherwise any 18mm spark plug non-fouler will work. Bonus points if you find the long ones instead of the pictured short ones, since no drilling is required if you do.
Old Feb 27, 2021
i am running magnaflow, no isses
kingrat
Sep 20, 2013 09:58 PM
danny3838
Jun 26, 2009 08:57 AM
v1rtu0s1ty
Sep 25, 2005 08:58 AM
knight4874
Oct 24, 2004 02:00 PM
2k3silver
Dec 10, 2003 02:30 PM
