damage timing belt broke, worth fixing?
Old Jun 15, 2019
Becki47's Avatar
Becki47 is an unknown quantity at this point
Originally Posted by nemosdaddy
Does the 2004 Civic LX 4 cyl have a timing belt or chain, and which damages the valves when it goes out?
My civic 2004 broke the timing belt. The estimated cost is $2094.00.
Is this worth it to fix?
Old Jun 15, 2019
Becki47's Avatar
Re: 2004 Honda Civic LX 4 cyl Timing belt/Chain
There are valves. It's s 4 cylinder
Old Jun 15, 2019
Becki47's Avatar
There are 2 cylinders that need to be replaced. The head needs to be machined
Old Jun 15, 2019
Slumpertcivic's Avatar
Very unlikely any pistons need to be replaced.
Belt breaks, piston bangs into valve(s) which bends the valve and makes a “shiny” spot on the piston.
What kind of repair shop are you getting that quote from?
A used JDM engine should be about $500 delivered, sure I would add in about $400 worth new seals, gaskets and such but then its just labor to take old engine out, move all the parts to the new engine and then install.
Iwantatruck
Mar 24, 2014 08:21 AM
sicken04
May 3, 2013 11:34 PM
TXFred
16
Mar 22, 2012 11:50 PM
lilhuff
Nov 18, 2011 06:11 AM
printolive
Jul 20, 2007 12:56 PM
