d17a1 vtec d17a2
Old Apr 16, 2020
AZOverlord's Avatar
AZOverlord is an unknown quantity at this point
d17a1 vtec d17a2
I use a d17a1 short block on 2005 honda civic ex special edition, I used the head off the vtec d17a2 .The car runs fine but I keep getting error code honda error code po340 . My question is the cam gear have the same amount of teeth ? I have counted them and I keep come up with one more tooth. Any input would be helpful.
Old Apr 16, 2020
FRSam's Avatar
Click Here
Re: d17a1 vtec d17a2
I'm pretty sure the tooth count is the same.
That code's for a CPS failure, and I'm almost certain that engages limp mode. I don't think that's the code that comes up when timing is off.
When I did the timing belt on my '01, I didn't have the sensor pushed in all the way so the code stayed on. It could be as simple as that.
Old Apr 16, 2020
AZOverlord's Avatar
Ok thanks for the input, so i should have an issue use the short block with the Vtec stuff ?
Old Apr 16, 2020
FRSam's Avatar
Click Here
Assuming you have all the appropriate wiring and ECU for the D17A2 (since that's the engine that came in an EX), you should be fine. It's a pretty well-documented swap, so it wouldn't hurt to verify that you took the same steps as what was taken in other threads.
Blake Kelly
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Jul 5, 2019 11:06 AM
lewolved
22
Jul 18, 2010 02:17 AM
jkilla34
Oct 28, 2008 10:08 PM
HwNpRyDe_CiViC
Feb 19, 2007 12:29 PM
robo1040
Aug 24, 2005 01:53 AM
