Valve cover thread
Old Feb 1, 2020
Tracecross30's Avatar
Tracecross30 is an unknown quantity at this point
Valve cover thread
So i was reinstalling my valve cover on my 02 civic and i realized that one of the long bolt at the back,the thread on the head where it bolt into messed up. i didn't draw on it tight but when i look at the thread on the bolt, it has a bad spat on 2 parts of the thread so thats what damaged the thread on the head..and solutions to fix so i can tighten that bolt?
Old Feb 1, 2020
Re: Valve cover thread
Chase the threads with a tap (on the bearing cap) and die (for the bolt). If the bearing cap is messed up too much, helicoil should do the trick
Old Feb 1, 2020
Ok,if its the thin piece of flat metal above the thread on the bolt you referring to as bearing cap,its fine.its just the thread on the head itself that got damage. So what size tap would that be.? The same as 10mm just just the bold size
Old Feb 1, 2020
Hol up. Sorry, it's been a minute since I looked inside of a D17. Can you take a pic of where the messed up threads are?
edit: IIRC, attached to the head are the cam shaft bearing caps, and that's what the VC bolts thread onto
Old Feb 1, 2020
Not tonight i will try tomorrow.its one of the 2 long 10mm bolts that bolt on the valve cover, the part that got messed up is where the bolt tightened on to the head..
ok,here's a screenshot of the back of the head .look beside the dipstick hole ,thes a small hole,the thread for one the long valve cover bolt.
Old Feb 1, 2020
BrotatoChip's Avatar
Super Moderator
Had that happen to mine a long time ago. I just ignored mine but you will have to use a helicoil as Riceboy said.
Old Feb 2, 2020
erm. I don't see a pic. lol
Old Feb 2, 2020
these bearing caps and some places on the top of the head is where the shorter valve cover bolts screw into. The longer 2 in the rear bolt onto the back side of the top of the cylinder head, IIRC. I remember stripping one or two of them out and I chased it with a tap and it seemed to hold fine, as long as I just snugged them down, approaching the feeling of stripping them out again. Helicoil would definitely give you more positive engagement of the threads
Old Apr 6, 2020
Hey bro. Back to the thread that stripped for my valve cover bolt,I'm looking at some sets of helicoils on ebay for various prices ranging from $15-40 bugs and sizes are 5m up to 8m .what size you think will work with mine.?
Clin_Diesel
25
Feb 17, 2016 07:34 PM
JuiceboxEH2
Apr 13, 2013 07:20 PM
sicma99ot
Buy, Sell, & Trade - Archive
Aug 5, 2010 09:49 PM
kerryman
Aug 5, 2010 04:17 PM
HonCiv02
Jul 30, 2007 03:27 PM
