Power loss when accelerating
Old Aug 12, 2019
roberts2036's Avatar
roberts2036 is an unknown quantity at this point
Question Power loss when accelerating
2003 4dr 5spd w/ 1.7, 174,000 miles, sometimes when I accelerating I lose power, but when I turn the car off and restart, it accelerating just fine. What could be the problem or things that I should start checking.
Old Aug 12, 2019
Slumpertcivic's Avatar
Re: Power loss when accelerating
My first thoughts are you have a failing fuel pressure regulator.
Maybe rent a fuel pressure gauge, connect it, and leave it connected.
Should read somewhere around 40-45psi? normally, drive until your getting poor acceleration symptom, pull over, open the hood and see where the gauge is at right then.
Second though is you have a chunk of your catalytic converter that broke loose and is intermittently blocking the exit.
Pretty much anything else would cause a engine code and light up your MIL.
Old Aug 13, 2019
I will start looking into to this weekend, Thx.
Old Aug 14, 2019
Is the fuel pressure regulator and part of the fuel pump assembly in the tank?
Due to the age and mileage I was planning to replace the fuel pump assembly.
Old Aug 14, 2019
I found it near fuel rail
Old Aug 15, 2019
The actual regulator is attached to the fuel pump inside the gas tank.
That part on the fuel rail is some sort of mysterious device.
Old Aug 15, 2019
BrotatoChip's Avatar
Super Moderator
I believe the thing on the fuel rail is a fuel pulsation damper. At least that's what I've found in other service manuals.
Old Aug 15, 2019
That sounds right, still mysterious, and defiantly not the issue here.
Wonder what the actual symptoms of one those failing, besides gas dripping out.
Jp7
18
Feb 9, 2019 07:22 PM
PacosTacos88
15
Mar 21, 2013 02:54 PM
Cleft_Asunder
Jul 17, 2010 02:00 PM
ajhdragon
Jul 31, 2005 07:42 PM
fourkilos
Apr 3, 2002 08:30 PM
