D17A2 Complete Rebuild Questions
Old Mar 11, 2020
Scallawagers's Avatar
SaltKnight0fNi
Scallawagers is an unknown quantity at this point
So I decided I will be saving up to do a complete rebuild under the hood of my 2004 Honda Civic EX (US). I know my way around the engine, and I know how to use a wrench. What I need is part recommendations. Does anyone know of a GOOD rebuild kit for this moter? I don't really want any major performance upgrades on the engine itself so any GOOD stock rebuild kit would be fine. I just want the best quality rebuild kit I can get without killing my wallet.
With upgrades in mind, I do plan on getting an aftermarket intake to make it look a bit cleaner under the hood. What intakes should I look at?
I also will be replacing the clutch when doing all of this. What are some good clutch kits to look into? I don't want any racing kits. Just a slightly better then OEM. Something that grabs a little harder but not so much that it just launches into gear. I know this is kind of specific, but i'm not sure what kind of clutch to get as I have not worked with many different clutches so i'm not sure what kind I like. Based off my description of what I want in the feeling, does anyone know of a good Clutch Kit that matches?
Old Mar 11, 2020
Colin42's Avatar
Re: D17A2 Complete Rebuild Questions
I used the excedy "OEM replacement" in my 05 and was really happy with it, can't comment on your other questions, sorry
Old Mar 13, 2020
mac25's Avatar
Dr Krieger of Modification
been there done that 😁
OEM
-head gasket
-rod bearings (probably leave main bearings unless play)
-rings (probably leave wrist pins)
-water pump/timing belt kit
-front/rear seals
-axle seals
Generic aftermarket parts brand
-valve seals
-liquid gasket
ARP
-head studs (for stock you can probably reuse you studs if you want)
scotttie17543
Feb 28, 2014 02:55 PM
civicdrifter93
Oct 10, 2011 02:22 PM
00celicagts6spd
Oct 29, 2003 03:28 PM
hothondacivic02
Bolt-on Engine Performance
Sep 12, 2003 07:06 PM
greatcasa
Feb 9, 2003 01:53 PM
