8th Gen 2006 - 2011.
06 Civic EX Sedan clutch upgrade
Old Oct 10, 2011
civicdrifter93's Avatar
civicdrifter93 is an unknown quantity at this point
Question 06 Civic EX Sedan clutch upgrade
Ive got a 2006 civic EX with basic performance mods(intake, exhaust) and in need of new clutch and wanting to upgrade it. I have a couple of questions-
Keep in mind im trying to get the best for the money. Willing to spend between 200-350. Maybe higher if it is worth it.
Do i get a clutch kit?
If not then what do i get, if yes then what are some good brands/wbsites to look at?
Old Oct 10, 2011
sl33pyriceboi's Avatar
Re: 06 Civic EX Sedan clutch upgrade
wht is wrong with ur clutch right now? is it slipping/worn out???
there are no real advantages for you to get a clutch kit (like a stage 1,2,3) unless you start making some real HP like in the 200whp+ and you beat the **** out of ur clutch.
with just intake/exhaust mod, all you will do is make ur clutch peddle heavier.
Old Oct 10, 2011
if ur stock clutch is fine, dont mess with it, unless you really want to have a heavier clutch for no reason....or have too much money and dont know what to do.
what will help you car out is if u get a lighter flywheel. the stock is somewhere between 18-22lbs. most aftermarket is about 8-10lbs.
Old Oct 10, 2011
My stock clutch is worn out. So just repalce it and get aftermarket flywheel?
usajags84
May 10, 2015 08:11 AM
bsmiley
Apr 27, 2015 01:27 PM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
dano2005
Apr 14, 2015 01:58 AM
