Evap system
Old Nov 14, 2019
Pcy97's Avatar
Pcy97 is an unknown quantity at this point
Evap system
Hi I have a 03 Civic. Been having problems with the EVAP system. I’ve changed the entire system and the check engine light keeps coming on. Anyone have any idea what else it could be the problem?
Old Nov 14, 2019
GolNat's Avatar
Prelude Owner
Re: Evap system
What is the code?
You did a smoke test of the system?
Old Nov 14, 2019
Pcy97's Avatar
Re: Evap system
Originally Posted by GolNat
What is the code?
code p1457 this code always comes up when the check engine light comes on. Yes did smoke test. Check all Hoses and no leaking. Even tightened up everything that’s connected to it. Changed gas cap. You name it. Mechanic can’t seem to figure it out either.
Old Nov 15, 2019
BrotatoChip's Avatar
Super Moderator
Re: Evap system
What exactly did you replace? You said the entire system was replaced.
When I had this code it was the canister shut valve. Here's another thread with this fault.
https://www.civicforums.com/forums/3...her-p1457.html
EMAN64
52
Feb 29, 2020 06:08 AM
Anticrime
Dec 2, 2011 09:46 AM
nameshift
Jan 30, 2011 04:40 PM
ZSKCivic01
Jul 21, 2009 01:42 PM
fuledya
Oct 27, 2006 03:39 AM
