2004 honda civic ex temp gauge and rpm not working
Old Nov 15, 2019
Mverret's Avatar
Kita
Mverret is an unknown quantity at this point
Driving on 10 car wouldn't get power of 40mph. Even when shift gears to fifth. If press gas car spits like bad gas. But after treatment still making same hesitant sound and neither temp gauge nor coolant gauge working.
Old Nov 15, 2019
Wankenstein's Avatar
Re: 2004 honda civic ex temp gauge and rpm not working
say what?
Old Nov 16, 2019
Mverret's Avatar
Kita
Originally Posted by HR Puffinblunts
say what?
Was driving. All of a sudden the car slowed down. Shifted to 2 to pick speed back up but the car started to hesitate. Took four off gas pedal. Then back on wouldn't go over 40mph. It like that for miles. I shifted to 1 speed stayed at 15mph then 2nd gear speed no more than 20 so on so forth. Car never made it over 40mph. And the rpm gauge not temp gauge work anymore.
The hesitation is similar to bad gas or not getting enough gas.
Old Nov 18, 2019
BrotatoChip's Avatar
Super Moderator
Engine light on? Pull fault codes.
Usually when gauges stop working in the cluster it is because an alternator mounting bolt is loose, possibly frying your ECM.
Old Nov 18, 2019
Mverret's Avatar
Kita
Started car Sunday. With foot on gas pedal RPM moved but I can hear a clicking under clove box area and check engine light flashes with clicking. Then clicking stops and with foot on gas pedal still engine light comes on ,car sputter and clicking stops.
Old Nov 18, 2019
Super Moderator
Check battery voltage with engine off/on.
Old Nov 18, 2019
Mverret's Avatar
Kita
That's good.
What about a relay?. And what is the clicking sound. Cause while clicking dials work. Once clicking stops car begins to loose power and sputter.
I so lost right now.
Help a lady out.
Old Nov 18, 2019
Super Moderator
Use a multi-meter to check the battery voltage. If you don't have one you may want to think about finding a reputable repair shop.
Old Nov 18, 2019
Colin42's Avatar
We want actual numbers, not "good"
Old Nov 18, 2019
Mverret's Avatar
Kita
Collins not understanding.
Also where is this cluster that's being mentioned located.
Old Nov 18, 2019
Marcelo Souza's Avatar
Marcelo Souza is an unknown quantity at this point
It’s sounding like your timing belt skipped some notches and threw off your ignition timing, the ruching sound might be a belt valve the misfiring would cause blinking of the engine light because it is misfiring and is growing it on limp mode why it isn’t going over 40mph
Old Nov 18, 2019
It’s an ex so it has Vtec so the valve timing is different after3.5- 4K if that is when your clicking stops that’s probably the problem
Old Nov 18, 2019
Check to see if your timing belt is loose
Ek787
Electronics
Mar 16, 2021 07:29 PM
americanlt
Feb 10, 2012 03:43 PM
oneSIck
Electrical
Aug 27, 2007 01:13 AM
taehoshi
20
Feb 11, 2006 11:25 PM
MangoEX
Dec 17, 2003 08:25 PM
