gas gauge not working
Old Aug 24, 2007
oneSIck's Avatar
oneSIck is an unknown quantity at this point
Hello to all. I need some help.
My gas gauge doest work period. Rpm, mph, temp gauges work fine. Do I need to replace the cluster or can I fix this. I checked the fuel pump fuse and its good.
So any post will help. Thanks.
Old Aug 27, 2007
YSIDRAG's Avatar
YSIDRAG is an unknown quantity at this point
Re: gas gauge not working
is this an 2001-2002 civic you r talking about? if so honda put out a TSB witch i think was turned in to a recall. the connector on the sending unit on top of the gas tank as a problem with coroding and not getting a good conection cuzing the guage not to work and in some cases cuzed the car to stall or or not start. check with your honda dealer to see if it was turned in to a recall or not. you may beable to have it fixed for free.
jay
Shakzhussain
May 17, 2015 12:03 PM
werdnahall
May 17, 2015 11:37 AM
Ashley Farr
May 7, 2015 05:01 PM
ORskier
May 3, 2015 12:54 PM
tylerginevan
Apr 27, 2015 12:29 PM
