Camshaft sensor failure
Old Aug 11, 2019
Stevil714's Avatar
DIY apprentice
Stevil714 is an unknown quantity at this point
Camshaft sensor failed and bought replacement. Have been googling and you tubing on how to replace the sensor. Was wondering if anyone had any pointers or help would greatly be appreciated. Or should I just bring it to a shop. My car has 276000 miles on it but motor only has around 45000. Please help a brother out. Thanks for your time.
Old Aug 11, 2019
Re: Camshaft sensor failure
  1. Take off valve cover. It at least loosen it so you can take the upper timing cover off
  2. Take off your timing over. Iirc, like 4 bolts?
  3. Disconnect pigtail harness from sensor.
  4. Remove mounting bolt from sensor, then remove sensor
  5. Install new sensor. Be careful because these things done play nice with being dropped or over-torqued
  6. Connect pigtail harness
  7. Install upper timing cover
  8. Install valve cover
It's really straightforward. Just make sure you torque the mounting bolt down properly and/or some blue thread lock
Old Aug 11, 2019
Slumpertcivic's Avatar
I would add in between step 3 and step 4.
Step 3.5 - shove a old shirt into every nook and cranny of the lower timing cover.
If you drop that mounting bolt taking it off or putting it on, your in for a whole lot more work...
oh yea step 5.5 remove old shirt.
Old Aug 11, 2019
Colin42's Avatar
Hopefully you bought an OEM sensor
Old Oct 28, 2019
Bombquad00's Avatar
Bombquad00 is an unknown quantity at this point
I have an 01 civic vtec replacing the tdc sensor.. I cant get to the plug to press the release tab because of the ABS module so close to the side cover... Any help plz... Thank you
Old Oct 28, 2019
Colin42's Avatar
Connector may be full of dirt and grime. Try hosing the connection with wd40 or brake clean
Old Oct 28, 2019
Bombquad00's Avatar
Its real clean .. Just cant get my hand (fingers) down there to squeeze the plug to release it due to the ABS being so close to the timing belt cover..I can get through the lines and hoses.. Just cant reach the plug.. Kinda inset..thank you
Old Oct 28, 2019
yeaaaahhh... that plug sucks to get to, and I have small hands, too.
Pull accessory belts, lift and swing the PS pump out of the way, remove alternator, remove driver's side headlight. Doing all that gives you some extra wiggle room to play with. It really easy to do all that, too. Got to a point where I could have all that taken out inside of 15 minutes.
Old Oct 30, 2019
guitarsnlikker's Avatar
guitarsnlikker is an unknown quantity at this point
Buy a honda oem valve cover gasket if you are replacing yours.
Carolyn Gilbert
Sep 10, 2019 11:58 AM
Aetoc
Engine DIY
Nov 4, 2016 08:07 PM
Toms49ers4life
Sep 9, 2013 11:22 PM
SwedeCivic81
Mar 1, 2010 11:30 PM
ryangt
15
May 18, 2008 10:01 PM
