2005 HONDA CIVIC 1.7L Primary Heated Oxygen Sensor (Primary HO2S)
I have a 2005 Honda civic 4 door manual, with an engine light that indicated the Bank1 Primary heated O2 sensor may need replacement).
I am having trouble sourcing the correct part#. I found NGK sells 2 types. NGK 24664 for a D17A2 Engine Desg, and a NGK 24665 for a D17A1 Engine Desg.
How do I determine which is correct and are there cheaper alternatives? These were about $300 CAN after taxes.
Thanks!
Crash
Thanks!
Crash
Re: 2005 HONDA CIVIC 1.7L Primary Heated Oxygen Sensor (Primary HO2S)
You need Denso or ntk, probably Denso. Thats what I used on mine. Look up the part number on Denso's website and then search for it online on either rockauto or Amazon. If on Amazon make sure it's a legit seller or you may end up with a counterfeit part. I paid around $150 cdn for mine on Amazon, took like 5 mins to change it. Buy an o2 sensor socket if you don't have one
RustyShackle
Oct 12, 2016 08:07 AM
badhaircut
Jan 31, 2014 08:04 PM
Meidilee
Oct 6, 2012 06:24 PM
ostetco
Jan 6, 2010 04:37 PM
