2001 Civic LX head Gasket Reinstall testing during assembly
I will be installing a new Honda head gasket on this 1.7. Before disassembly the HG problems was diagnosed by applying compressed air to the cylinders which made the radiator level rise up in cyl #1.
How little can I reassemble before doing some testing on the HG to verify installation?
Thanks !
Thanks !
Re: 2001 Civic LX head Gasket Reinstall testing during assembly
Most likely full reassembly before testing as you will want oil to coat block and internals during the post repair leakdown (cylinder injection) test.
Here's a good video on head gasket replacement tips:
While it's at the machine shop it would be a good time for new valve stem seals. The machinist should inspect for cracks, warpage and leaky valves.
I'm in upstate NY if someone has "a guy" for a machine shop. I don't know of any local to me. Otherwise I'll pick something out of the phone book.
You can get a surprising amount of information from the parts counter.
Honda1998Civic
Feb 13, 2016 12:04 AM
Civic82GL
Apr 30, 2014 07:50 PM
