Code p1361 tdc sensor 1 noise
Old May 1, 2020
Venado7's Avatar
Venado7 is an unknown quantity at this point
I have a 2002 Honda Civic lx
While I was driving down a highway around 50mph or so, my car basically shut down on me
the check engine light came on and the car was not accelerating it slowed to a stop and I had to park it on the side I opened the hood and saw nothing really wrong visually with the car I waited about 10 minutes and the car turned right on
The check engine light was still on so I went to autozone to get it checked and I got a code reading p1361 tdc sensor 1 noise
But I then remembered that I recently change my tdc sensor about 3 months ago
PLEASE HELP!
what could be the issue
I Just got my head gasket and a whole new head installed a week ago don’t know if that would affect the sensor
Old May 1, 2020
Re: Code p1361 tdc sensor 1 noise
Did you use an OEM sensor or aftermarket during the last replacement?
Old May 1, 2020
Venado7's Avatar
No I just bought one from autozone
Old May 1, 2020
For sensors, I'd go Honda OEM. Majestic Honda and Bell Honda are two of my go-to online sites for Genuine Honda OEM parts for relatively cheap.
Old May 1, 2020
Venado7's Avatar
Hey forgot to mention that the Check engine light went out and the car drives somewhat normal
I’m scared it will come back on again tho
could it be the wiring ??
Old May 1, 2020
Possibly? keep an eye on it. Double check your grounds and sensor connections. I know the TDC sensor is kind of a pain to get to
Old May 1, 2020
Colin42's Avatar
Cheap crappy sensor will probably act up again once it gets hot enough, get an OEM one
Old May 1, 2020
Venado7's Avatar
I will keep checking on it for some days and if it starts acting up that’s probably what I’ll do thank you
Old May 1, 2020
BrotatoChip's Avatar
Super Moderator
Can also try picking up a used OEM one from a junkyard if you don't want to spring for a new one.
Old May 2, 2020
Venado7's Avatar
That’s probably my best bet right now
NinjaGirl54
Feb 2, 2023 10:28 AM
Tracecross30
Electrical
Jul 5, 2019 08:46 AM
GotU420
Sep 10, 2018 07:09 PM
got2run5
Feb 2, 2012 10:30 PM
IRPancake
Oct 8, 2009 12:21 PM
