IAT sensor circuit high voltage
Old Jul 4, 2019
Tracecross30's Avatar
Tracecross30 is an unknown quantity at this point
Angry IAT sensor circuit high voltage
i just got some codes pop up on my scanner
permanent code TDC, P1361 cam sensor. Is need to be change ?i am hearing a noise after i rebuilt the engine and put everything back together and this code explained something about noise to so i might need to check my timing again before things get worse.
P0113 IAT sensor circuit high voltage
and the other is a Cat code which i already know about.
this IAT one needs to be change as well or it can be dealt with some other way?
some pros advise needed here pls.:
Old Jul 5, 2019
Slumpertcivic's Avatar
Re: IAT sensor circuit high voltage
Straight off the WWW thingy.
  • IAT is bad, and needs replaced.
  • IAT is good, but oil has contaminated it (on the tip).
  • Wiring harness has been damaged/shorted.
  • Backfiring has occurred in the intake manifold. This can fry/contaminate the sensor.
  • PCM failure.
Dint forget the obvious, did you actually plug it back in..
Old Jul 5, 2019
Yes, I plugged it back in..
Old Jul 5, 2019
GolNat's Avatar
Prelude Owner
Check wiring and pull the sensor and see how it looks.
Old Jul 5, 2019
Ok...
Adam925
Jul 26, 2016 07:48 PM
michael0219
Sep 1, 2015 10:25 PM
phnxcivic
Feb 20, 2014 11:12 PM
threeoten
Nov 4, 2012 01:56 AM
ivanhatch
Oct 16, 2012 06:11 PM
