What should support the air filter housing?
Old Jul 16, 2019
Nohippychicks's Avatar
Nohippychicks is an unknown quantity at this point
I removed the filter housing when I changed the head gasket and goodies that go with it; since then, a lot of time has passed and I installed the filter and housing yesterday but it doesn't seem like it's supported correctly with just the grommet over the throttle body.
I noticed that there are a couple of mounting holes on the forward outboard part of the housing that would perfect for making a nice rigid mount but there's nothing for them to mount to.
Maybe I lost a bracket, maybe it wasn't there before the teardown; who knows? Maybe the rest of the intake tubing, which I've yet to install, is what gives the filter housing some stiffness?
Either way, can someone give me a picture (or part number) of whatever brackets help support the filter housing? Maybe it's something I have hanging around that I looked at and didn't recognize.
Old Jul 16, 2019
Slumpertcivic's Avatar
Re: What should support the air filter housing?
One bolt attaches it to a point basically on the fuel rail, that locks it down pretty good, then when you attach the resonator it all interlocks.
You did tighten down the clamp that holds it to the throttle body yes?
asian
May 11, 2005 02:37 PM
gearbox
Bolt-on Engine Performance
18
Sep 22, 2004 05:38 PM
StealthCivic
Jun 17, 2004 01:59 PM
civicfreak84
Jun 14, 2004 07:14 PM
louie1234
Mar 9, 2002 08:06 AM
